Jun 15, 2017 7:16 PM UTC
Web.Link programs started in multiple Creo Parametric sessions will not run correctly.
PTC Document - CS239645
  • When we start Web.Link program (html files containing JavaScript with Web.Link APIs)  in multiple Creo Parametric  sessions will not run correctly.
  • The behavior is  that in one session the Web.Link program is working fine ( the session with the first call of web.Link) and the Web.Link code called in the other session will  try to connect to the only one session where the Web.Link program was called first.
  • When for example the Web.lInk code in the one session is waiting for some user inputs in this cased the other session will hang until the program in the first session si completed.
  • the only way to get it to work is to close all the Creo Parametric session  and open only new one.
Has anyone found a work around for this? I submitted this to PTC a year ago and they said it would be fixed in Creo 4. Well I just install Creo 4 and it still is happening.
Has anyone else had this issue?
7-Bedrock
Sep 8, 2017 9:32 AM UTC
Please try for Creo 4.0 F000: BROWSER_UNIQUE_ENGINE ON (hidden)
Kind Regards
Andreas
