MikePhillips
Jun 30, 2011 9:31 PM UTC
Weblink and drawing symbol groups
I accidentally posted this in the CAD forum...might have more luck
here. 🙂
I have a symbol that I would like to place on a drawing using Weblink. This
symbol has numerous groups. I would like to programmatically select certain
groups before I place the symbol. Looking through the Weblink API
documentation, it appears that Weblink can only show ALL the groups, NONE
of the groups or present a dialog to the user to pick from the available
groups.
Is this the case? Is it possible to select a group? If not, does anyone
have a work around?
I'm trying to work this out using the RunMacro() function as a temporary
work around.
Thank you in advance,
Mike Phillips
Jul 1, 2011 5:16 AM UTC
Michael,
you can specify which groups should be displayed.
There is an example in the Weblink User?s Guide.
See the second code example ? the function is called ? placeDetailSymbol?.
Andreas
MikePhillips
Jul 1, 2011 12:47 PM UTC
Thank you Andreas!
You are correct. I gave the example a try and it's going to give me what I
need.
Mike
