Feb 25, 2010 9:19 AM UTC
Wf4 - 64bit
Hello, I'm developing a full asyncronous application for Wildfire 4.
I've successfully compiled and linked everything on my 32 bit machine, but i can't link for a 64 bit machine: i can't get rid of this error
LINK : fatal error LNK1104: cannot open file 'comsuppw.lib'
I'm using the Windows Server 2003 64-bit Build Environment of the Platform SDK:
These are the libraries :
e:\Programmi\ptc\PROEWILDFIRE4.0_M030\prodevelop/x86e_win64/obj/prodevmt.lib
e:\Programmi\ptc\PROEWILDFIRE4.0_M030\protoolkit/x86e_win64/obj/protkmt.lib
e:\Programmi\ptc\PROEWILDFIRE4.0_M030\protoolkit/x86e_win64/obj/ptasyncmt.lib
bufferoverflowu.lib libcmt.lib kernel32.lib user32.lib wsock32.lib advapi32.lib mpr.lib winspool.lib netapi32.lib
psapi.lib gdi32.lib shell32.lib comdlg32.lib ole32.lib e:\JavaArchive\jdk1.6.0_17_64\lib\jvm.lib
Here are the compiler flags (includes are not listed) (Microsoft (R) C/C++ Optimizing Compiler Version 14.00.40310.41 for AMD64)
cl /MT /TC -c /wd4430 -fp:precise -DUSE_ANSI_IOSTREAMS -D_CRT_SECURE_NO_DEPRECATE -DPRO_USE_VAR_ARGS -DPRO_USE_VAR_ARG -D_USE_32BIT_TIME_T -DWILDFIRE_4 /Od /Z7 /DDEBUG -DPRO_MACHINE=36 -DPRO_OS=4
And these are the linker flags (Microsoft (R) Incremental Linker Version 8.00.40310.39)
link /nodefaultlib:libcpmt.lib /subsystem:console -out:e:\Progetti\attivi\installazione\lib\64bit\jprotoolkit.exe /dll /debug /machine:amd64 @longline.list
Did anyone ever experienced the same problem?
Pietro Bianco
Feb 25, 2010 1:19 PM UTC
Pietro,
You need to use Microsoft Visual Studio 2005 for Wildfire 4. In the
configuration manager, you can change from 32 to 64 bit builds.
Bob
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
