18-Opal
Apr 25, 2018 4:03 AM UTC
What APIs should be used to import subcomponents?
You can use CurrentModel to get the model that exists in the session.
Let's assume that the model that exists in the session is an assembly.
What APIs should I using when trying to get subcomponents of a assembly (parts, drawings, assemblies, etc.)?
pfcAssemblyComponentsGetReturn? pfcAssembly?
I'll appreciate for your help.
Any other comments?
kind regards
2-Explorer
May 9, 2018 2:04 PM UTC
Hi
Could not get your first point. I mean what action you want to achieve through first point?
Refer below for other two points:
2. ProSelect() with char option[] as prt_or_asm
3. ProSolidDispCompVisit() or use ProSolidFeatVisit() with filter function such that feature type is of component type using API ProFeatureTypeGet()
HIH.
2-Explorer
May 2, 2018 3:58 PM UTC
Seems you are using VB. Net... I am toolkit user and does not have API installed for VBAPI with me as of now.
For toolkit, we use ProSessionMdlList.
HIH,
Ketan
CHASEONHO18-OpalAuthor
18-Opal
May 3, 2018 1:12 AM UTC
@Ketan_Lalcheta Thank you.
What APIs should I refer to if I get a list (subcomponent) for the selected item?
I am currently trying to create a parameter manager with the toolkit.
The required functionality looks like this:
1. The specific model (top-level, or sub-specific assembly)
2. Prompt window to select a specific model
3. After selecting a specific model, display the subcomponents, a text box to manage parameters, and some buttons
We would appreciate it if you could give us some good examples or API information for each function.
Let me first review protk_appls.
Your help can save me time!
Thank you.
2-Explorer
Hi
HIH.
