Oct 8, 2020 10:12 AM UTC
what is the difference between protoolkit and otk toolkit
hey, I am trying to automate the creo parametric through running parallel application using asynchronous mode. which toolkit should I use and what is difference between these toolkit and have any example available  for asynchronous mode.
18-Opal
Oct 8, 2020 7:04 PM UTC
Depending on what you are trying to do....
This may be very useful....
http://www.creoson.com/
Dave
Oct 11, 2020 6:36 PM UTC
If to be short
Toolkit - C library based on a functions
Otk - C++ or Java. Classes and objects in baseis of the library.
