7-Bedrock
Why is my KBody reversed?
First, I'm not sure if this is the correct forum for GRANITE questions. If not, please point me to the appropriate community.
I'm creating a KBody instance and for some reason KBody::IsReversed() is returning true. When I ask the triangulator to create tristrips for me, they are coming back with the normals pointing inwards. Is it up to me to reverse the tristrips and normals?
Cory
CoryAnswer
7-Bedrock
I did get a response from GRANITE tech support. Unfortunately it wasn't what I wanted to hear. There isn't much I can do. Essentially, it's just the way the API works.
FWIW, I was following the procedure from task 9 in the GRANITE User Guide.
Community Moderator
Hi @Cory,
Thank you for your question.
Anurag
Cory7-BedrockAuthorAnswer
7-Bedrock
