Aug 27, 2015 12:35 PM UTC
Wildfire 2 (M280) Motion Engine running on Windows 7 x64...
We have an old licence of PTC Pro Mechanica standalone (Wildfire 2, datecode M280).  Structure runs happily on Windows 7, as does the Motion UI, but I cannot get the Motion UI to connect to the Engine to run motion analyses.  The response I get is:
COMMAND:
Opening "..\..\..\..\Work\Temp\Mass_modes_01" ...
The model "..\..\..\..\Work\Temp\Mass_modes_01" is now current.
COMMAND:
Run
Checking validity of design study ...
Starting a private Mechanica Motion engine ...
Unable to connect to the Mechanica Motion engine.
*** WARNING *** Unable to connect to the Mechanica Motion engine.
*** WARNING *** Save model and exit.
COMMAND:
It seems to be possibly an installation issue, as the 64bit install has a different working directory (C:\CAE\PTC\mechWF2\x86e_win64) to previous 32bit installs.
Does anyone have any ideas on how to resolve this?  I have MS Visual C++ installed and DotNET 3.5 running, but no joy!!
Thanks for any suggestions, Dominic
Tried asking in Analysis & Simulation but it was suggested that I ask here instead.
Ancient Pro Mechanica Motion on Windows 7
Tried installing a 64bt C++ compiler but that didn't change the error message.
2-Explorer
Sep 18, 2015 5:49 PM UTC
Wow, Mechanica Motion! This has been really a long time we had questions about it!
I only remember that it needed a compiler/linker to generate the code to process the analysis.
Maybe there is not even a 64-bit library version available? See this post: Mechanica Motion WF2, C Compiler on XP-64?
The other idea: I remember that you had been able to install Mechanica independent from Pro/ENGINEER and hence it was required to specify the Mechanica directory from the Pro/ENGINEER installation. Did you check this (of course, if other Mechanica modes like Structure or Thermal work OK, then skip this suggestion)
Gunter
