Aug 22, 2011 3:22 PM UTC
Wildfire 4: How to get list of models in workspace
currently I don't have a INTRALINK or PDMLink installation available and a customer asks the following (simple?) question:
Is it possible to get a list of models that are currently in the (current/active) workspace?
Toolkit, Weblink/VB/Jlink ???
With WF5 I know there is an enhancement in the ProFilesList() command where you can use a wtws:// (or something like that) as the directory path.
But does anyone know what's the correct command/method in Wildfire 4?
Thanks.
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Rudolf-Diesel-Str. 6
D-65439 Floersheim / Germany
phone: +49 6145 598296
mail: -
Aug 22, 2011 3:36 PM UTC
I think some clarification is needed.
If you are not using INTRALINK ro PDMLink, workspaces are not used and therefore do not exist.
Gerry
In Reply to Andreas Hellmann:
Aug 22, 2011 5:22 PM UTC
Yes... I know. What I wanted to say: I cannot test it at the moment. My
customer of course has PDMLink?
Aug 22, 2011 5:57 PM UTC
Can you just log into his pdmlink? There is no client software. If he can get you access thru VPN - then you would register his windchill server, and set his workspace as active.
Aug 23, 2011 6:18 AM UTC
Andreas, take a look at the last post in this thread: http://portal.ptcuser.org/p/fo/st/topic=13&post=98587#p98587
Bjarne Frandsen
(Pro/ENGINEER Wildfire 4.0 M170andWindchill 9.1M060 on Windows)
