Jan 30, 2026 6:21 PM UTC
Windchill wtpart with creo OTK
I am able to load a cad part or cad assembly from windchill to creo parametric, but would it be possible to load the related cad part from a windchill wtpart with the creo OTK?
Or is it possible to use windchill methods in the java code for parametric?
Thx
Feb 12, 2026 8:24 AM UTC
I solved this by using the Windchill Odata rest API's in the free java OTK. This goes fast and can be used to get the 3D cad or the drawing.
20-Turquoise
Jan 30, 2026 10:12 PM UTC
Don't know if this helps but in 13.0.0.0 there is a new ootb Open In Creo action for wtparts:
https://support.ptc.com/help/windchill/r13.0.2.0/en/#page/Windchill_Help_Center/NewandChanged/NewandChanged_WWGM_13_0_0_0_NewActionPartCADtools.html#
Jan 31, 2026 4:29 PM UTC
Hi Randy,
I saw the new feature from Windchill 13 to parametric, which is also great to have now. But I'm looking for the other way around. I have a workaround, but it would be great to have some direct API's to do this.
Thanks for your answer.
rvanveerdeghem12-AmethystAuthorAnswer
