Thanks for all your detailed answers.
I guess it's not possible to unroll the W11 update. I have hoped that someone in the community is using the same W11 version(s) and using the revision check in ME10. But there is no feedback.
I assume you have tried to re-install your ME10 package.
If you do have access to a 2nd system... did you try over there as well? Same result?
The error message "You have more than one part named .. " is the standard one and can be easily recreated using INIT_PART commands. What I stumbled about in the error message you posted is that there is only ONE unique part ID mentioned in the brackets at the end of the message. That is strange.
May be you can create a ME10 trace, creating a log file? May be we can see something unusual in it.
For the case you don't know how to:
- trace del_old 'c:/temp/calling_rc_load.log' { this starts logging to a file, adapt the file pathname }
- call your revision check with the files you like to compare
- confirm the error message
- trace off { this stops logging to a file }
● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
