Blank Windows
I am in CREO and my windows all go blank?
All the files are still there in the top window menu and grouped in the toolbar at the bottom. I am also able to save my files and see the text activity in the status area at the top.
Any thoughts on how to remedy this without exiting out?
Doug
Creo elements/pro5.0 M100
WIN 7
Hi Doug,
I has once the same failures everytime my custome code produce fast changes. A minimize and maximize of the complete windowstack often force the WF to repaint the window content. Not everytime, but often that works and is only a workaround. Do you know which of your commands inside your code get you inside this situation?
Best regards,
Eike
