Fatal behaviour of change_locale
In our company we have Creo Elements Drafting with server-side startup scripts loaded, that include a lot of text notes in Shift-JIS encoding. The default language of Creo Drafting 18.1 is Japanese.
When trying to use change_locale 'en' the Creo Drafting standard menus, and buttons are switched to English words, but the program completely looses the ability to load any script with Japanese text inside.
Windows 7x64 has Japanese system locale set up.
Is there a way to force English standard menu/buttons, while keeping Japanese locale for reading scripts in Shift-JIS?
Hello
for macro's have a look in the "Program Reference Guide"
for the command
DEFINE_ENCODING
Best regards
hhale1-VisitorAuthor
As I mentioned earlier, macros are server-side. This means, I can not change macros.
I need to change menu buttons to English text, while maintaining Japanese locale.
Can you please be more specific about DEFINE_ENCODING. How should I use it outside the macros mentioned?
you can find some more information in the installation directory of drafting "appendix.htm"  "Section 7: Unicode Support"   "Macro file encoding"
outside the macros, I think that this does not work.
