High RMS Stress error estimate
I am running a multipass analysis set to converge within 5%. I am confused about what exactly the RMS stress error Estimates is tellling me. When I run my analysis I get what looks like a very large stress error.....
RMS Stress Error Estimates:
Load Set Stress Error % of Max Prin Str
Load-Rear 5.06e+04 65.4% of 7.73e+04
Local Stress Error Estimates:
Load Set &nb sp; Stress Error
max over max over
model selected elements
Load-Rear 111.4% 0.0%
Yet it also says this:
The analysis converged to within 5% on
edge displacement, element strain energy,
and global RMS stress.
Measure convergance is really tight except Von Mises which is slightly above 10%. What steps can I take to reduce the RMS Stress Error Estimate?
Use p-level quantity to determine areas with high level of polynome. Try to reduce max element size for these areas.
I found I got silly RMS error estimates (10^4%) when excluding elements from the convergence in WF5
Just an FYI.... This was found to be a bug, and SPR 2076498 was filed.
Not me then. However, I can't find SPR 2076498 by sensible searches in the support site.
