How do I make a new coordinate system the active one?
I am trying to move a part. The 3D copilot appears (I think that is what it is called, the 3d thing with the arrows and rings that you pull to move an object) but it wants to move the part in directions that are set at 45 degrees offset from the directions I need to move the part. I tried to see if there was a way for me to reorient the global coordinate system but could not find a way to do that. I created a new coordinate system successfully - but it has no effect on anything! What good is a new coordinate system if you can't move parts or measure relative to it????? I see no way to make it the active coordinate system. I looked through the help file and so far have not found a way to make a new coordinate system the active one.
I also tried creating a new workplane and then orienting it in the appropriate direction and then pressing F8 to show the coordinate system of that plane (which is oriented as I need it to be) but then when I go to move the part the 3d copilot is oriented according to the global coordinate system and not the one associated with the workplane. So that method doesn't work.
What am I missing here?
I am using Creo Elements/Direct Modeling Express.
wdesmetAnswer
i think you should check the Ref. Focus in the Position dialog box. its value is probably set to 'face'; change the value to 'All' and try to select the edge
You don't have to use the 3D copilot as it appears. Once it appears you can click on faces, edges, workplanes, etc.. to reorient it.
Ok. When I click on a face the 3d copilot disappears and another related type of 3d moving device appears which operates only in the direction normal to the face I clicked. That will work well enough. Thank you.
That is still the 3D copilot. It will only display the available movements options based on what is selected. If you pick an edge you will see more options.
