Many sheets - drawing to pdf
Greetings,
I am on Creo 6.
I have 128 sheets in my drawing. I attempt to create a pdf and it freezes. There are some sheets with graphics, but most are boms.
Any tips on getting this to work - or am I at the limitations of Creo?
WayneF
What messages are you getting when it fails?
Is the Cad working timing out on publishing the drawings?
wfalco16-PearlAuthor
No message. Just hangs. I had it going for hours the other day. I killed it.
In the WVS Job Monitor, what does the Job log show?
What is your wt.properties setting for publish.cadtimeout.drawing?
What is your wvs.properties setting for publish.cadagenttimeout?
