Modelling Express 6.0 Drill Holes
Hi I am new to Modelling Express this seams an obvious question but how do I drill a hole in an existing model. I have an STL from a manufaturer for a simple ABS plastic box consisting of 6 parts the base, the lid and the 4 screws. My question is how do I drill a hole in the base I have created a workplane and drawn a circle but I cannot seem to create a hole in the one side of the box. If I use punch it goes through both sides of the base. When I look online there is only reference to the drill command which is not present in modelling express. So how do I do it?
StephenW
Jonathan,
You should move this question to PTC Creo Elements/Direct category under PTC Creo.
The base level of the PTC Creo forum is used for Creo Parametric.
jnewbould1-VisitorAuthor
Hi Stephen reposted it in PTC Creo Elements/Direct
