Nov 2, 2023 8:39 PM UTC
Newbie needs formats
Ok, I'm new to Creo, but not parametric CAD.  I'm a one man operation and I can do the modeling part, but I was suprised there were no drawing formats supplied with Creo.  Is there a place I can get drawing formats without creating them from scratch?  Even the tutorials only show importing *.dxf for creating the formats, not from scratch.
Nov 2, 2023 8:46 PM UTC
You didn't look deep enough in the folders that Creo installs.
Under the loadpoint, find the Common Files folder and in there us a folder named Formats.
It contains very basic A through E sized formats.
They arren't hard to create. Mine use a lot of tables for the parameter driven data. I also use tables for static data. That makes it easy to make a change to the master and then roll them out to the different formats.
