Problems with construction lines
hello, I hope that somebody can help me, i have a Modeling PE 2.0 in my laptop is Windows vista home edition, and i cant see a construction lines on workplane, i already try to turn on/off cinstruction line visibility but still no working. thanks in advance
Hello Jucius I'm not sure but your problem is Home Premium. PE 2.0 or other version dosen't runninng on Home Premium,but need the up-grade to Businnes or ultimate. Regards
Sounds like a graphics issue. Make sure your graphics card fully supports OpenGL. That is one of the system requirements listed on the download page. If your computer has Intel graphics, this is probably your problem. They do not support OpenGL. You can search this forum and find many similar problems caused by Intel graphics. One other thing you can try. Set the following system variable. SDPIXELFORMAT=SOFTWARE (Google "setting environmental variables" if you do not know how to do this) This will bypass your graphics card driver software when you run Modeling PE. Or, you can disable hardware acceleration in your graphics settings.
I have tried and what you have said, but unfortunately still does not work my graphic card is ATI radeon, it supports OpenGL. Thanks
