Save STL not available
I work with Creo Elements/Direct Modeling 18 on two different machines. One of them lists STL in save>file type while the other does not. The software version is the same, the model I'm working on is loaded from the same pkg.
Any ideas?
Thanks a lot!
The STL Data interface must be turned on.
1. From the Applications tab, click on the corner arrow of the Base module.
2. From the Modules box, click on Startup.
3. From the Modules list, select STL from the Data Interfaces section.
4. Click on Add to add it to the Startup Sequence.
5. Click OK
6. Restart Modeling.
5. Click OK
It works!
Many thanks again!
