7-Bedrock
Jan 11, 2023 10:01 PM UTC
Show Model Annotations are too big when added
have a busy hole pattern, using Show Model Annotations I am adding the datum axes, but they are too big and overlapping. How do you change the size of when they are first added? (I know how to change them manually once they are added).
Jan 12, 2023 5:10 AM UTC
Click on File > Settings > Auxiliary Geometry,
then double click on the value to change it for new center lines:
Jan 18, 2023 7:17 PM UTC
Hello TomK
May I ask which cad program you are using?
If it is Creo 6 or another Creo Parametric related, then you are here in the wrong forum.
Here you are at Community Creo Elements Direct in the Drafting subsection.
