visual studio and modeling
Does somebody know how to connect visual studio 2013/2015 with Creo elements direct modeling 18.1? DDE doesn't exist anymore in visual studio. Somebody has an idea and/or example to do this?
Thanks in advance
What do you have in mind?
With Visual Studio you are typically develing C++ or .NET to "extend" CED Modeling
Another usage of Visual Studio is to compile LISP sources into DLLs to be loaded into CED Modeling
What do you want to achieve with DDE?
I guess you want to "talk" to CED Modeling?
I want to use visual studio to make some kind of menu that talks trough DDE with modeling. But the new visual studio software doesn't use DDE anymore, so maybe there is another way to solve this problem?
DDE has been deprecated by Microsoft many years ago, therefore it is no longer available in Visual Studio.
Do you want to talk to Modeling from "outside" (=from a application which is not Modeling itself)?
