what is the "percentage" shown in the lower right corner of the Model Manager window?
lfortnerAnswer
I assume it's a ratio between used memory and max memory as:
(total - free)/max
where:
- total: the total amount of memory in the Java virtual machine
- free: the amount of free memory in the Java Virtual Machine
- max: the maximum amount of memory that the Java virtual machine will attempt to use
When you press the mouse in this panel, it's supposed to run the garbage collector, a process where the Java Virtual Machine expends best efforts toward recycling unused objects in order to make the memory they currently occupy available for quick reuse.
lfortner14-AlexandriteAnswer
(total - free)/max
where:
Hi Louis and Pete,
The interesting part is how you get this panel.
I don't have it in my MM V19 😞
Cheers,
     Max
Hey Max,
There are several conditions that make this panel appear. Let have a look at ManagerPanel.java, init().
The most current is when you debug the application from NetBeans..
Alternatively when your environment variable DEBUG_MM is "true".
Hope this helps you.
