Any Info about planned API-changes with the new UI?
Hi all,
as we have many tools around Integrity in our environment, which helps us to have functionalities which Integrity can't deliver itself, we were wondering how this will work with the new UI.
We have built an adapter to connect to Integrity and this adapter is used by the most of the above mentioned tools. This adapter is mainly using the client-side API at the rich client, because this client is already installed at the machines of our users. But the rich client will be obsolete in the future and it is also not an option to install the client only to have an integration point for accessing the API.
So at least our adapter has to be reworked to use any new API, and certainly this will also change some way to use this adapter, so the connected tools needs changes too. We need some time for this, therefore we need info about any plan for an API or any other way to connect to Integrity as soon as possible.
Thanks, Jens
