Java Customizations
We are using many Java customizations to get special Word/Excel exports/imports, charts, formatting, trace propagation and cross domain copying in our integrity clients.
How do you plan to integrate those features in the Web Gui?
              The JAVA APIs continue to be supported when we introduce the new UI. The goal is to ensure all Use Cases that a user can run using a Swing or Web Client will be possible in the new UI.
    Can you explain more about cross domain copying by helping me understand the use case and how does this work today?
    Kartik
    fkullmann1-VisitorAuthor
    Hello.
    cross domain copying is a feature that allows to copy nodes from one document to another if the documents are in different domains. That means that they have different fields. The cross domain custom feature provides fields to be copied that are in both document available (like the text field).
    Regards
    Frank
