UI Replacement Meeting 8 - Document View
At first thanks to you to be part of the session to get an overview of your future plans.
Based on the presentation of today I have several questions
  1. Is the new document view and outline view the only existing view in the document?
  2. Will this view be applied to each kind of document or only to these documents which have subdocuments included?
  3. How can we ensure to get a view of the document, which is “readable”? Our business units work close together with our suppliers
  4. How should we ensure to run filters through the whole document?
  5. Are we still able to export the documents to Word, Excel, ReqIF?
  6. If several types of content is able to be stored in the document, the attributes in each of these types might be different. How can you ensure, that filters and exports will be configurable to these documents?
  7. We plan to migrate from doors to Ingegrity. What does it mean to migrate this data?
  8. Which impact will we get for reuse of information, branch of documents?
Based on the issues Martin identified in the current implementation, I was not able to see, how the modified model will solve this. Are you able to give a more detailed overview?
Thanks Kai
