Advanced Artisan APC-Metadata.xml File
This is an example of an advanced apc-metadata.xml file for use with Axeda Artisan that includes examples of how to create different data structures on the platform, including Expression Rules and System Timers.
Step 1 - In the upload.xml make sure the artisan-installer is 1.2
    <dependencies>
        <dependency>
            <groupId>com.axeda.community</groupId>
            <artifactId>artisan-installer</artifactId>
            <version>1.2</version>
        </dependency>
    </dependencies>
Step 2 -
<?xml version="1.0" encoding="UTF-8"?>
        apc-metadata.xml
<apcmetadata>
    <models>
        <model>
            <name>DemoModel</name>
            <!--standalone or gateway-->
            <type>gateway</type>
            <DataItems>
                <DataItem>
                    <name>PendingMessage</name>
                    <!--string or digital or analog-->
                    <type>string</type>
                    <visible>false</visible>
                    <stored>true</stored>
                    <!--0 = no history,1 = Stored,2 = no storage,3 = on change-->
                    <storageOption>2</storageOption>
                    <readOnly>false</readOnly>
                </DataItem>
                <DataItem>
                    <name>ConsumableData</name>
                    <type>string</type>
                </DataItem>
            </DataItems>
        </model>
    </models>
    <ruleTimers>
          <ruletimer>
              <name>SFTP Retry</name>
              <description></description>
              <!--midnight gmt-->
              <schedule>0 0 0 * * ?</schedule>
              <rules>
                  <rule>SFTP Retry</rule>
              </rules>
          </ruletimer>
    </ruleTimers>
    <expressionRules>
                <rule>
            <enabled>true</enabled>
            <applyToAll>true</applyToAll>
            <type>SystemTimer</type>
            <ifExpression><![CDATA[true]]></ifExpression>
            <thenExpression>
                <![CDATA[ExecuteCustomObject("SFTPRetry")]]></thenExpression>
            <elseExpression></elseExpression>
            <consecutive>true</consecutive>
            <models>
                <model>DemoMOdel</model>
            </models>
        </rule>
    </expressionRules>
    <customobjects>
        <customobject>
            <name>GetChartData</name>
            <type>Action</type>
            <sourcefile>GetChartData.groovy</sourcefile>
            <params>
                <param name="username" description="(REQUIRED) The name of the calling user"/>
            </params>
        </customobject>
        <customobject>
            <name>GetChartData_rss</name>
            <type>Action</type>
            <sourcefile>GetChartData_rss.groovy</sourcefile>
            <params>
            </params>
        </customobject>
        <customobject>
            <name>GetAddress</name>
            <type>Action</type>
            <sourcefile>GetAddress.groovy</sourcefile>
            <params>
                <!--<param name="username" description="(REQUIRED) The name of the calling user"/>-->
            </params>
        </customobject>
    </customobjects>
    <applications>
        <application>
            <description>Chart Example</description>
            <applicationId>chartexample</applicationId>
            <indexFile>index.html</indexFile>
            <!--<zipFile></zipFile>-->
            <sourcePath>artisan-starter-html/src/main/webapp</sourcePath>
        </application>
    </applications>
</apcmetadata>
