Axeda: Create and then delete a data item on a model
This code snippet creates then deletes a data item to illustrate CRUD technique.
Parameter:  model_number
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.device.ModelFinder
import com.axeda.drm.sdk.device.DeviceFinder
import com.axeda.drm.sdk.data.CurrentDataFinder
import com.axeda.drm.sdk.data.HistoricalDataFinder
import groovy.xml.MarkupBuilder
import com.axeda.drm.sdk.device.DataItem
import com.axeda.drm.services.device.DataItemType
* DeleteDataItem.groovy
* Delete a data item.
* @param model_number        -   (REQ):Str name of the model.
* @author Sara Streeter <sstreeter@axeda.com>
def response = [:]
def writer = new StringWriter()
def xml = new MarkupBuilder(writer)
try {
// getUserContext is supported as of release 6.1.5 and higher
    final def CONTEXT = Context.getUserContext()
// find the model
    def modelFinder = new ModelFinder(CONTEXT)
    modelFinder.setName(parameters.model_name)
    Model model = modelFinder.findOne()
// throw exception if no model found
    if (!model) {
        throw new Exception("No model found for ${parameters.model_name}.")
// Add a dummy data item
DataItem dataitem = new DataItem(CONTEXT, model, DataItemType.STRING, "MyDataItem");
dataitem.store();
// find the data items on the model
model.dataItems.each{
    logger.info(it.name)
    if (it.name=="MyDataItem"){
        it.delete()
} catch (def ex) {
      xml.Response() {
    Fault {
          Code('Groovy Exception')
          Message(ex.getMessage())
          StringWriter sw = new StringWriter();
          PrintWriter pw = new PrintWriter(sw);
          ex.printStackTrace(pw);
          Detail(sw.toString())
return ['Content-Type': 'text/xml', 'Content': writer.toString()]
