20-Turquoise
Clear out the "HTTP header: referrer" and "cookie" error in 7.4+
Sometimes the following error is seen filling up the application log: "HTTP header: referrer".
It does not cause noticeable issues, but does fill up the log. This article has been updated to reflect the workaround: https://www.ptc.com/en/support/article?n=CS223714
To clear the error, locate the validation.properties ​inside the ThingworxStorage\esapi directory.
Then  change the values of both Validator.HTTPHeaderValue_cookie and Validator.HTTPHeaderValue_referer to:
Validator.HTTPHeaderValue_cookie= ^.*$
Validator.HTTPHeaderValue_referer= ^.*$
