22-Sapphire I
Example to do Regions - RegionsExample.xml
I had a better example, this is my original example ... If I find the other one I'll upload that as well.
7-Bedrock
Hey PaiChung,
Kudos to you, I was able to create different regions thanks to this, but now I'm facing a different problem regarding the changing the color of the region created, is it possible to assign a color to each region, based on a value?
Best Regards,
António
