HAProxy SSL Passthrough configuration
This is going to cover one way of configuring an SSL passthrough using HAProxy.  This guide is intended to be a reference document, and administrators looking to configure an SSL passthrough should make sure the end solution meets both their company's business and security needs.
Why use SSL Passthrough instead of SSL Termination?
The main reason for ThingWorx would be if a company requires encrypted communication internally, as well as externally.  With SSL Termination, the request between the load balancer and the client is encrypted.  But the load balancer takes on the role to decrypt and passes that back to the server.  With SSL Passthrough, the request goes through the load balancer as is, and the decryption happens on the ThingWorx Application server.
What you will need to continue with this guide:
  • HAProxy installed
  • A working ThingWorx application server (Guide to getting one setup can be found here)
  • Tomcat configured for ssl
    • NOTE : Always contact your Security team and make sure you have a certificate that meets your business policy
    • For this tutorial, I created a self-signed certificate following along with the below guide.  If you have already obtained a valid certificate, then you can just skip over the step of creating it, and follow along with the Tomcat portion
    • Once configured, restart Tomcat and verify it is working by navigating to https://<yourServer>:<port>/Thingworx
With ThingWorx running as SSL and HAProxy installed, we just need to make sure the HAProxy configuration is setup to allow SSL traffic through.  We use 'mode tcp' to accomplish this.
On your HAProxy machine, open /etc/haproxy/haproxy.cfg for editing.  While most of this can be customized to fit your business needs, some variation of the highlighted portions below need to be included in your final configuration:
global
        log /dev/log    local0
        log /dev/log    local1 notice
        chroot /var/lib/haproxy
        stats socket /run/haproxy/admin.sock mode 660 level admin
        stats timeout 30s
        user haproxy
        group haproxy
        daemon
        # Default SSL material locations
        ca-base /etc/ssl/certs
        crt-base /etc/ssl/private
        # Default ciphers to use on SSL-enabled listening sockets.
        # For more information, see ciphers(1SSL). This list is from:
        #  https://hynek.me/articles/hardening-your-web-servers-ssl-ciphers/
        # An alternative list with additional directives can be obtained from
        #  https://mozilla.github.io/server-side-tls/ssl-config-generator/?server=haproxy
        ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS
        ssl-default-bind-options no-sslv3
defaults
        log global
         option tcplog
         mode tcp
         option http-server-close
         timeout connect 1s
         timeout client  20s
         timeout server  20s
         timeout client-fin 20s
         timeout tunnel 1h
         errorfile 400 /etc/haproxy/errors/400.http
         errorfile 403 /etc/haproxy/errors/403.http
         errorfile 408 /etc/haproxy/errors/408.http
         errorfile 500 /etc/haproxy/errors/500.http
         errorfile 502 /etc/haproxy/errors/502.http
         errorfile 503 /etc/haproxy/errors/503.http
         errorfile 504 /etc/haproxy/errors/504.http
        frontend https
         bind *:443
         mode tcp
         default_backend bk_app
        backend bk_app
         mode tcp
         server TWXAPP01  <twxapp01IP>:<port>
In this example, the user would connect to https://<loadbalancer>/Thingworx and the load balancer would forward the requests to https://<twxapp01IP>:<port>/Thingworx
That’s it!
A couple of side notes:
  • The load balancer port the clients connect to does not need to be the same as the ThingWorx port the load balancer will forward to
  • If working in a Highly Available configuration, each ThingWorx Application server needs to have its own certificate configured
  • If HAProxy seems unstable, try updating to the latest release
    • If it is on the latest release according to the Unix repository, check https://www.haproxy.org/ and see if there is a later stable release.  There have been some issues where Ubuntu's latest update in the repository is actually a few years old
