Incoming CSV File Parsing - Populating the Axeda Enterprise
These code snippets illustrate parsing CSV files and populating the Axeda Enterprise with data, locations and organizations.  These files are incoming to the Axeda Platform.
Note:  These snippets do NOT handle null values in the CSV due to the lack of a CSV parsing library.  Workaround is to populate empty values with an empty or null signifier (such as a blank space) and test for these on the Groovy side.
Code Snippets:
CSV file to Data Items
CSV file to Location Organization
Script Name: CSV file to Data Items
Description: Executed from an expression rule with file hint "datainsert", takes a CSV file and adds data based on values.
Parameters:
OPTIONAL - only needed for debugging
  1. modelName - (OPTIONAL) Str - name of the model
  2. serialNumber - (OPTIONAL) Str - name of the serial number
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.device.DeviceFinder
import com.axeda.drm.sdk.device.ModelFinder
import com.axeda.drm.sdk.device.DataItemFinder
import com.axeda.drm.sdk.data.DataValueEntry
import java.util.regex.Pattern
import groovy.json.*
import com.axeda.drm.services.device.DataItemType
import net.sf.json.JSONObject
* CSVToData.groovy
* Executed from an expression rule with file hint "datainsert", takes a CSV file and adds data based on values.
* @note  There must be a column with "model" and one with "serial".  The rest of the columns should be data item names with values
* in the rows. DOES NOT handle null values in CSV.  Workaround is to insert blank spaces in null values and test for those on the Groovy side.
* Solution would be to add a library for CSV parsing such as open csv.
* @params - only needed if NOT executed from expression rule - primarily for debugging
* modelName - (OPTIONAL) Str - name of the model
* serialNumber - (OPTIONAL) Str - name of the serial number
* initialize our global variables
* json = the contents of our response
* infoString = a stringBuilder used to collect debug information during the script
* contentType = the content type we will return
* scriptname = The name of this Script, used in multiple places
def json = new groovy.json.JsonBuilder()
def infoString = new StringBuilder()
def contentType = "application/json"
def scriptName = "CSVToData.groovy"
def root = ["result":["items":[]]]
def columns = []
try {
  Context CONTEXT = Context.getSDKContext()
  def modelIndex
  def serialIndex
  // initialize Model and Device Finders
  ModelFinder modelFinder = new ModelFinder(CONTEXT)
  DeviceFinder deviceFinder = new DeviceFinder(CONTEXT)
  // implicit object compressedFile
  File file = compressedFile.getFiles()[0].extractFile()
/* //begin non-expression rule code, useful for debugging
    File file
    modelFinder.setName(Request.parameters.modelname)
              def model1 = modelFinder.find()
    deviceFinder.setSerialNumber(Request.parameters.serialNumber)
    deviceFinder.setModel(model1)
    def d = deviceFinder.find()
     UploadedFileFinder uff = new UploadedFileFinder(CONTEXT)
    uff.device = d
    def ufiles = uff.findAll()
    UploadedFile ufile
    if (ufiles.size() > 0) {
        ufile = ufiles[0]
        file = ufile.extractFile()
*/ //end non-expression rule code
  file.eachLine {line ->
      def row = line.tokenize(',')
      // set the column headings
      if (columns.size() == 0){
        columns = row
        // find model and serial index, assumes there's a column that has "model" and "serial", otherwise take columns 0 and 1
        def modelpatt = Pattern.compile(/[A-Za-z_\-]{0,}model[A-Za-z_\-]{0,}/, Pattern.CASE_INSENSITIVE)
        def serialpatt = Pattern.compile(/[A-Za-z_\-]{0,}serial[A-Za-z_\-]{0,}/, Pattern.CASE_INSENSITIVE)
        modelIndex = columns.findIndexOf{ it ==~ modelpatt } > -1 ? columns.findIndexOf{ it ==~ modelpatt } : 0
        serialIndex = columns.findIndexOf{ it ==~ serialpatt } > -1 ? columns.findIndexOf{ it ==~ serialpatt } : 1
      // otherwise populate data
      else {
          modelFinder.setName(row.get(modelIndex))
          def model = modelFinder.find()
          deviceFinder.setModel(model)
          deviceFinder.setSerialNumber(row.get(serialIndex))
          def device = deviceFinder.find()
          def assetInfo = [
                    "model": model.name,
                    "serial": device.serialNumber,
                    "data":[]
          row.eachWithIndex{ item, index ->
              if (index != modelIndex && index != serialIndex){
                def dataItemName = columns[index].replace(" ","")
                DataItemFinder dif = new DataItemFinder(CONTEXT);
                dif.setDataItemName(dataItemName);
                dif.setModel(model);
                DataItem dataItem = dif.find();
                if (dataItem){
                    if (item.isNumber()){
                       item = Double.valueOf(item)
                    DataValueEntry dve = new DataValueEntry(CONTEXT, device, dataItem, item)
                    dve.store()
                else {
                    DataItem newDataItem
                        newDataItem = new DataItem(CONTEXT, model,DataItemType.ANALOG, dataItemName)
                    else {
                       newDataItem = new DataItem(CONTEXT, model,DataItemType.STRING, dataItemName)
                   newDataItem.store()
                   DataValueEntry dve = new DataValueEntry(CONTEXT, device, newDataItem, item)
                    dve.store()
                assetInfo.data << [
                        "name": dataItemName,
                        "value": item
              root.result.items << assetInfo
  logger.info(JSONObject.fromObject(root).toString(2))
} catch (Exception e) {
    processException(scriptName,json,e)
//return ['Content-Type': 'application/json', 'Content': JSONObject.fromObject(root).toString(2)]
    Processes the contents of an Exception and add it to the Errors collection
    @param json The markup builder
private def processException(String scriptName, JsonBuilder json, Exception e) {
    // catch the exception output
    def logStringWriter = new StringWriter()
    e.printStackTrace(new PrintWriter(logStringWriter))
    logger.error("Exception occurred in ${scriptName}: ${logStringWriter.toString()}")
        Construct the error response
        - errorCode Will be an element from an agreed upon enum
        - errorMessage The text of the exception
    json.errors  {
        error {
            message     "[${scriptName}]: " + e.getMessage()
            timestamp   "${System.currentTimeMillis()}"
    return json
Script Name: CSV file to Location Organization
Description: Executed from an expression rule with file hint "locorginsert", takes a CSV file and adds orgs and locations based on values.
Parameters:
import com.axeda.drm.sdk.contact.Organization
import com.axeda.drm.sdk.contact.Location
import com.axeda.drm.sdk.contact.OrganizationFinder
import com.axeda.drm.sdk.contact.LocationFinder
import com.axeda.drm.sdk.data.UploadedFile
import com.axeda.drm.sdk.data.UploadedFileFinder
* CSVToLocOrg.groovy
* Executed from an expression rule with file hint "locorginsert", takes a CSV file and adds orgs and locations based on values.
* @note  There must be a column with "model" and one with "serial".  The rest of the columns should be either parts of a
* location or an organization.  The location parts columns should be prefixed with the org# that they correspond to.
* DOES NOT handle null values in CSV.  Workaround is to insert blank spaces in null values and test for those on the Groovy side.
def scriptName = "CSVToLocOrg.groovy"
def columns = []
try {
  def modelIndex
  def serialIndex
  def locIndices = [:]
  def locKeys = ["line1","line2", "address1", "address2", "city","state","zip","country", "org"]
  // initialize Finders
  LocationFinder locationFinder = new LocationFinder(CONTEXT)
  OrganizationFinder organizationFinder = new OrganizationFinder(CONTEXT)
    File file
    uff.device = d
    UploadedFile ufile
        ufile = ufiles[0]
        columns = row
        locKeys.each{ key ->
            // construct a regex for each key and create a map for finding/creating
            def locPatt = Pattern.compile(/[A-Za-z0-9_\-]{0,}${key}[A-Za-z0-9_\-]{0,}/, Pattern.CASE_INSENSITIVE)
            def colIndex = columns.findIndexOf{
                    def match = it =~ locPatt
                    if (match){
                        return match?.getAt(0)
            if (colIndex > -1){
                locIndices[colIndex] = key
      else {
          def assetInfo = [
                    "locs":[]
          def locMap = [:]
          def orgName
          def locKey
          def locBool = false // make sure we get some criteria
              if (index != modelIndex && index != serialIndex && item && item != ""){
                  locKey = locIndices[index]
                  if (locKey){
                      locBool = true
                      if (locKey == "address1"){
                        locKey = "line1"
                      if (locKey == "address2"){
                        locKey = "line2"
                      if (locKey == "org"){
                            orgName = item
                      // don't execute if we've got an organization key
                      else {
                          // for finding
                          locationFinder[locKey] = item
                          // for creating (if needed)
                          locMap[locKey] = item
          assetInfo.org
          Organization org
          if (orgName){
              organizationFinder.setName(orgName)
              org = organizationFinder.find()
              if (!org){
                org = new Organization(CONTEXT, orgName)
                org.store()
          Location loc
          if (locBool){
              logger.info("with bool")
            loc = locationFinder.find()
            logger.info(loc?.name)
          if (!loc){
              def line1 = locMap["line1"]
              def name = line1?.replace(" ","")?.replace(/\./,"")?.replace("_","") + "_Loc"
              def line2 = locMap["line2"]
              def city = locMap["city"]
              def state = locMap["state"]
              def zip = locMap["zip"]
              def country = locMap["country"]
              if (line1 && city){
               loc = new Location(CONTEXT,name,line1,line2,city,state,zip,country)
               loc.store()
              if (loc && org){
                  org.addLocation(loc)
                  org.store()
          assetInfo.locs << [
                   "name": loc.name,
                    "line1": loc.line1,
                    "line2": loc.line2,
                    "city": loc.city,
                    "state": loc.state,
                    "zip": loc.zip,
                    "country": loc.country
                   assetInfo.org = [
                        "name": org.name
    json.errors  {
        error {
    return json
