Installing Thingworx Analytics Builder part 3 of 3
In this video we cover the installation of the UploadThing module.
This video applies to ThingWorx Analytics 52.2 till 8.0. This is no longer applicable with ThingWorx Analytics 8.1
Useful links:
Updated Link for access to this video:  Installing Thingworx Analytics Builder: Part 3 of 3
I am trying to install the UploadThing on Ubuntu Server 14.04.5 LTS
UploadThing_Install-52-2.zip
This is the errors I get:
duan@ubuntu:/tmp$ sudo sh ./install.sh
-en
Checking java version...
-e OK
Where do you want to install 'UploadThing' [/opt]?
./install.sh: 1: ./install.sh: Bad substitution
./install.sh: 142: [: ==: unexpected operator
sudo: chkconfig: command not found
/etc/init.d/UploadThing: line 8: /etc/rc.d/init.d/functions: No such file or directory
Starting UploadThing: /etc/init.d/UploadThing: line 19: runuser: command not found
touch: cannot touch ‘/var/lock/subsys/UploadThing’: No such file or directory
/etc/init.d/UploadThing: line 23: success: command not found
The script seems to be targeted specifically at Centos and seems incompatible with Ubuntu.
I would appreciate any help.
cmorfin19-TanzaniteAuthor
Hi Duan
Can you try using the script from https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS246768 ?
Kind regards
Christophe
Thanks for the link Christophe,
This is the content of the updated install.sh:
#!/bin/sh
version=1.0
uploadThingDir=/opt/UploadThing-${version}
if [ ! -f ${uploadThingDir}/bin/UploadThing ]
then
    uploaddir=
    while [ -z $uploaddir ]
    do
        read -p "Where is the 'UploadThing' installed [/opt]? " uploaddir
        if [ -z $uploaddir ]
        then
            uploaddir="/opt"
        fi
        uploadThingDir=${uploaddir}/UploadThing-${version}
        then
            echo -e "\n****  This is not where 'UploadThing' is installed, try again\n"
            uploaddir=
        fi
    done
fi
cat UploadThing.ori | sed -e "s|::uploaddir::|${uploadThingDir}|g" > UploadThing
cp UploadThing /etc/init.d
chmod 755 /etc/init.d/UploadThing
chkconfig UploadThing on
service UploadThing start
Unfortunately it seems it is not compatible with Ubuntu 14.04.5
./install.sh: 28: ./install.sh: chkconfig: not found
Starting UploadThing: touch: cannot touch ‘/var/lock/subsys/UploadThing’: No such file or directory
/etc/init.d/UploadThing: line 17: runuser: command not found
/etc/init.d/UploadThing: line 21: success: command not found
As far as I can tell the problem lies with chkconfig:
My research shows:
The command chkconfig is no longer available in Ubuntu.The equivalent command to chkconfig is update-rc.d.This command nearly supports all the new versions of ubuntu.
The similar commands are
update-rc.d <service> defaults update-rc.d <service> start 20 3 4 5 update-rc.d -f <service>  remove
Hi Duan
Thank you for the feedback.
Then it would seem there is indeed an issue on Ubuntu newer releases.
I am checking on this and will update you when I get more information
Regards
Christophe
Hi Duan
I have reported this to R&D as the install script does not work indeed on latest release of Ubuntu.
You can find more details at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS257078 .
For now one way around it is to Create, configure and Upload the dataset through REST API, then use ThingWorx Analytics Builder to manage the uploaded dataset.
Kind regards
Christophe
