Live Webinar: Top 5 Thingworx environment monitoring best practices
We will host a live Expert Session: "Top 5 Thingworx environment monitoring best practices" on March 25th, 10h00 EST.
Please find below the description of the expert session and the registration link.
Expert Session: Top 5 Thingworx environment monitoring best practices
Date and Time: March 25th, 10h00 EST
Duration: 1 hour
Host: Tori Firewind, Tim Atwood and Dave Bernbeck from Enterprise Deployment Center
Registration Here: https://www.ptc.com/en/resources/iiot/webcast/top-5-thingworx-monitoring-best-practices
In this session, we will be reviewing the main monitoring practices to keep a heathy environment and discuss the main issues from the audience. Bring your questions!.
Existing Recorded sessions can be found on support portal using the keyword ‘Expert Sessions’.
You can also suggest topics for upcoming sessions using this small form.
Here are some recorded sessions that might be of your interest. You can find recordings for the full library of webinars using the keyword ‘Expert Sessions’ in PTC support portal search
Thingworx Active Active Clustering
This session will cover the main aspects of the High Availability Clustering feature launched with the ThingWorx 9.0 release.
Recoding Link
Upgrade to Thingworx 9 – How to Plan / Evaluate Impacts
This session highlights the key points you should evaluate to properly plan your upgrade to Thingworx 9.
Recording Link
Top 5 items to check for Thingworx Performance Troubleshooting
How to troubleshoot performance issues in a Thingworx Environment? Here we cover the top 5 investigation steps that will help you understand the source of your environment issues and allow better communication with PTC Technical Support
Recording Link
