ThingWorx Analytics Publish Model using TW.AnalysisServices.AnalyticsServer.AnalyticsServerConnector
Underneath video walks through how to Publish a Model from Analytics Builder into Analytics Manager using the connector named TW.AnalysisServices.AnalyticsServer.AnalyticsServerConnector.
This step is keep failing on me.
I have TW Foundation 8.3.1 and TW Analytics 8.3.1. I am following demo on "Operationalize an Analytics Model" (https://developer.thingworx.com/en/resources/guides/operationalize-analytics-model/analysis-model).
After pressing "Publish" button following message appears:
Application log message:
Unable to deploy model to TW.AnalysisServices.AnalyticsServer.AnalyticsServerConnector
I found only THingPredictor related issues on this step. (not it).
abarki5-Regular MemberAuthor
Hi @tcoufal,
Would you be able to share the extension you are using? I can then attempt to recreate the issue, and investigate.
Thank you,
Abarki
You mean extension which adds Analytics Builder and Analytics Manager into the Composer?
I used one which was bundled with Analytics Server installation package.
