Jun 30, 2017 8:14 PM UTC
Why has the install stopped during the 'Servlet Engine' install step?
There are a few recommended troubleshooting steps to alleviate this:
1. The best practice is to install without an existing Tomcat implementation. Verify whether Tomcat is currently installed on this PC. If so, uninstall Tomcat and run the installer again.
2. Assign a different port for the servlet engine. This can be changed within the server.xml file located here:
<Install path>\ThingWorxManufacturingApps\PTC_Servelet_Engine\conf\server.xml
3. If the installer has stopped at approximately 90% complete, and 5 minutes have elapsed, start the ThingWorx Servlet Engine Service manually from this directory in the Windows Explorer:
<Install path>\ThingWorxManufacturingApps\PTC_Servlet_Engine\bin\thingworxServerw.exe
4. The Servlet Engine log files can be used for advanced troubleshooting. They are located in this directory by default:
<Install path>\ThingWorxManufacturingApps\PTC_Servlet_Engine\logs
