3-Newcomer
about simulator
how are you?
I want to use simulator ( type of channel) send data to our company app.
what should I do at kepserverex?
cmoreheadAnswer
@JL_10854133,
You should be able to use the Kepware OPC UA Client Driver if the company app has the ability to act as an OPC UA server. Here is a link to the UA Client Driver product page:
OPC UA Client (ptc.com)
A MQTT connect may also be made with MQTT Client Driver. Here is the link to that product page:
MQTT Client Driver (ptc.com)
 I recommend opening a support ticket with the Kepware team. Here is a link to the login page where a support ticket can be opened. Kepware has a dedicated team that provides pre-sales consultation.
Log In | My Kepware
*Chris
@JL_10854133,
The KEPServerEX application is designed to get real time data from manufacturing devices and send that data to HMI/SCADA systems via OPC UA or DA. Does your company app support OPC DA or UA communications. What protocol does the company app support?
*Chris
3-Newcomer
how are you Chris ?
OPC-UA and Mqtt support our company app.
regards
jiaqi
cmorehead13-AquamarineAnswer
@JL_10854133,
Log In | My Kepware
*Chris
