Adding a SLC 5/05 communicating with TCP/IP in Kepware
I am trying to add 2 separate SLC 5/05 plc's in our Kepware server using Allen Bradley Ethernet driver because both of the PLCs is networked. We have also used the DF1 driver with the ethernet encp. but that did not work either. Nothing sees the PLC.
We then tried adding a test SCL 5/05 PLC in our training room with a small network for a controlled environment and it still will not see the PLC.
Kepware EX6-6.16.203.0
rajskumarAnswer
Hello,  Please take a look at the following article as it may help resolve your issue:
CS314647 - Basic Slot Configuration of an Allen-Bradley SLC500 model device in KEPServerEX / ThingWorx Industrial Connectivity
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.Thanks
rajskumar16-PearlAnswer
