After KepServerEX Activation transfer, Modbus Suite driver is time limited
- 1 reply
- 990 views
- Translate All
Hi, I moved a few licenses between computers. One of the licenses appears to be "good", but anytime I use it the log indicates it is time limited... After 2 hours, the driver does indeed stop.
Is there anything I can do to enable this activation if it is not in an active support contract?
The other licenses moved without issue.
The original computer was KepServerEX 6.9 and the new computer is 6.10. Are licenses tied to Kep versions?
