3-Newcomer
Feb 10, 2023 2:39 PM UTC
Alert When Modbus TCP Device Goes Offline
Is there a way to send out alerts from Kepware whenever a connected Modbus TCP/IP device disconnects?
For example, when these errors are shown:
Thank you!
rjanardanAnswer
Feb 10, 2023 4:19 PM UTC
You should look into the _Error tag from the _System tag group of the device.
rjanardan16-PearlAnswer
Jimmy_T3-NewcomerAuthor
3-Newcomer
Feb 10, 2023 9:13 PM UTC
I like this approach.
We are going to use the Advanced IoT Plugin to scan the "_System._Error" device tags.
If they are true, then there is a disconnection. If they are false, everything is working fine.
Thanks!
