ASCII string CR insert
Dear community,
I am trying to connect to a device with UCON;
I can communicate with the device with ASCII strings over a terminal;
unfortunately it doesnt work if I enter my ASCII string in Kepware.
The device only recognizes ASCII strings; if I copy my ASCII string from a converter with the CR and LF into the terminal it works and responds.
If I try to insert the string into Kepware's Interface it doesnt work.
Manully inputing the string and entering  ALT+13 for CR and ALT+10 for LF also doesnt work.
The device doesnt answer to the string.
How else can I enter CR and LF into the interface?
I can't seem to find anything about it on the net or help.
Thanks in advance.
Alright, solved the problem.
For non printable characters you have to use the "Write character" command.
can you see Kepwares output?
Try chr(13)  and chr(10) ?
write character 0x0D  0x0A
Doesnt work. If I try to send it with ASCII HEX (0x74 0x74 0x3d 0x67 0x72 0x0d 0x0a) or ASCII string with tt=gr0x0d0x0a
I get the output (in ASCII): 30783734203078373420307833642030783637203078373220307830642030783061
