Atlas Copco MT Focus 6000
Using the Open Torque Tool Protocol driver, I am struggling connecting a Atlas Copco MT Focus 6000 (not Power Focus). According to the Kepware driver supported devices, this is a supported device. However, it has proven impossible to connect to the LTR tags and the 1201/1202 tags to get torque results. We have validated that the 'Communication' messages are successful and valid, and can validate data via diagnostics. However, the driver does not recognize the data format and sets most tag quality to 'Bad (Out of Service)' We have tried every message revision and MID8 / MID60.
Is it truly possible to get torque result data from an MTF6000 using Kepware's Open Torque Tool Protocol driver?
MKhatriAnswer
Support
Greetings!!
Recommended Resolutions:-
The MT Focus 6000 uses a MicroTorque‑specific Open Protocol variant, which does not match the standard Open Protocol format expected by Kepware’s Torque Tool Ethernet driver, causing parsing failures. [support.ptc.com]
Kepware’s driver is validated for Power Focus and other standard Open‑Protocol tools, not MT Focus 6000, so LTR / MID 1201 / MID 1202 torque results cannot be reliably
What to do
Use an Atlas Copco MT‑specific interface (e.g., MT API or ToolsTalk MT).
Or create a custom Open Protocol client following MT Focus 6000 protocol rules.
Optionally submit a device‑support request to Kepware for future compatibility.
Mohit
MKhatriCommunity ManagerAnswer
Support
Greetings!!
What to do
Mohit
3-Newcomer
It is possible to establish communication for the MT Focus 6000 using Kepware. Please navigate to Device1 -> Properties -> Settings and configure the Options parameters as follows:
  • Disable Tool on LTR: Disable
  • Revision Format: One
  • Use Generic Subscribe: Enable
  • Use Unsolicited Data Packing: Enable
Afterward, you can define the tag addresses you want to read by referencing the address maps in this official manual: Atlas Copco ServAid Manual (PDF).
Example Tag Addresses:
  • Final Torque: 1202.30237 (Float)
  • Final Angle: 1202.20238 (Float)
Best Regards,
Muhammed AKIN
Support
Greetings!!
Yes, it is possible to establish communication between the MT Focus 6000 and Kepware. Navigate to Device1 → Properties → Settings and configure the following options:
Once these settings are applied, you can create tags in Kepware using the address definitions provided in the Atlas Copco ServAid address map documentation. Configure each tag with the appropriate address and data type as specified in the manual.
Mohit
