Brother cnc machine CNC -D00 OPC configuration for X,YD,M tags
I am trying to connect Brother cnc machine CNC -D00 to ignition through opc protocol. I am receiving D,M registers tag, but x,y tags are not coming in opc. Can anyone support?  Is there any configuration//setting need to be done to expose X,Y tags from brother cnc though opc protocol.?
pshashipreetham
Hi @BG_10139888
If you can tell me:
  • What OPC server or driver you using
  • Whether it is OPC DA or OPC UA
  • And what tags can you currently see
Then I can give more direct advice on how to get X and Y tags working.
Thanks.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
