Can I use Kepware to get the data from Toshiba controller TC200
Dear Sir,
Can I use Kepware to get the data from Toshiba controller TC200. If yes, how can I do it?
Hello, Nuttaphon Netmugda.
I have reached out to our Kepware team to get you an answer for this.
Thank you,
-- Craig A.
Greetings Nuttaphon,
The short answer to this question is no, there is not a KEPServerEX driver that will interface directly with the Toshiba TC200. I am currently looking into a past use-case where a customer may have used the User Configurable (UCON) driver in KEPServerEX to build a custom transaction with the TC200. I am going to email you from the Kepware Technical Support queue to discuss more.
Best regards,
Steven M
Nuttaphon1-VisitorAuthor
Thank you guys. The Kepware technical support contact me already. If I have any update I will update you again.
