3-Newcomer
Capture timestamp value via advance tags
Hi
We need to capture the timestamp property of a PLC tag through advance tags module.   We need  the hour in which the data of one tag has been changed..  How can we do it?   We are using kepserverEX  v6.16.203.
Thanks in advance
What are you capturing it to? If a database the time stamp will be generated there.
3-Newcomer
   yes, we could do it with a trigger in SQL.  We want to know if there is a method to capture the timestamp of a TAG in kepware  in order to use it in advance tag module.
Support
Greetings,
Kepware does not include any methods for capturing tag timestamps, which is a significant limitation that needs to be addressed.
Mohit
