May 15, 2020 2:14 AM UTC
Chinese characters become garbled are writing to Kepware from Thingworx
I have a remote thing bound to Kepware in Thingworx.   The data type is String in Kepware ,  it works well if I write number or english alphabet,  however ,  if write chinese character then it become garbled in Kepware , please check the attached picture .
If I set chinese character in Kepware directly,  then Thingworx can read it and display correctly.  Only write has problem.
Any idea about it ?
Thingworx 8.5.2
Kepware: KEPServerEX 6
Sean
seancccAnswer
May 19, 2020 2:13 AM UTC
@zyuan1 ,
Thanks, I've created a ticket to Kepware and it's been confirmed to be a bug in Kepware 6.6, and the issue has been fixed in 6.8.
Sean
May 15, 2020 2:33 AM UTC
It's kind of like an encoding issue, you should create a Kepware case for it.
seanccc17-PeridotAuthorAnswer
@zyuan1 ,
Sean
Support
May 19, 2020 5:57 PM UTC
Hi @seanccc.
Glad you found the solution!  Please mark your last post as the Accepted Solution for the benefit of others with the same issue.
--Sharon
