Compability Modbus suite 6.7
Hello Everyone,
You know if Modbus Suite has compatibility with Windows server 2022?
Regards
MRohillaAnswer
Support
Greetings,
PTC Kepware products (drivers and suites) are tested against major operating system versions. Because of the complex nature of software deployments and interactions, compatibility of installed software and operating system updates is largely a function of the specifics of the software installed. For this reason, PTC recommends that customers test any software updates in a sandbox environment that replicates their production environment before applying those updates to their production environment.
Mohit
Greetings @TL_12115123,
Could you please elaborate on your requirements? This will help us understand your needs better and provide you with the most appropriate solution.
MRohillaCommunity ManagerAnswer
Support
Greetings,
Mohit
