3-Newcomer
Connect kepware with http connector
I have an application and i can send data using HTTP connector. How to add that HTTP connector in kepware?. If i change some data in application and send it through connector it need to be reflected in kepware.
It seems you can use our IoT Gateway's REST server agent to achieve this. Once a REST server agent is created, a client may connect to the endpoint to browse, read, and write tags configured under that agent.
As this seems to be a Proof of Concept (POC) project, we have a dedicated team (Application Engineering) that handles all POC-related queries and concerns. You can reach out to them for assistance.
Solutions Consulting: presales.support@kepware.com
