Connect Kepware with TW Studio trial
Community,
I'm trying to connect Kepware with the Thingworx cloud instance that is part of the Studio trial. I've already created the key and thing in Thingworx and I've changed the settings in the Kepware project that I'm using, but I'm unable to connect. I'm getting error messages saying that the web socket connection cannot be established. I can see the thing linked to Kepware in the monitor application in Thingworx but it is red instead of the usual green.
Do you know which additional settings/parameters I need to change (URL of the server at which Kepware is pointing) for this to work?
Currently I'm traveling for a meeting and I'm unable to share some screenshots of the errors/configurations that I'm using, but as soon as I have access to my server I can post it back here.
Thanks for your support.
Best regards.
Hi Omar Salinas​,
Have you connected the Kepware to any other ThingWorx instance before or is it the first time?
Please share the configuration/errors once you are free so that we can check the same.
Anyone know how to do this? Connecting from KepServerEx data to Thingworx Studio using external data?
Avinash Boddu​: One way is to first have your KepServerEx connect to ThingWorx. Then use ThingWorx entities/services to populate data inside ThingWorx Studio.
Do you have your KepServerEx connected to ThingWorx instance which is associated with Studio?
-Durgesh
