Connection attempt to runtime failed.
When I open KEPServer it gives me an error that says "Connection attempt to runtime failed" in the event log. Then it times out and gives me a dialog box asking if I want to work offline.
The latest project was not showing. I tried to open the project, but it had not been saved. So I tried to open an older project. It opened and I tried to connect the runtime and again it failed. I checked Task Manager and the runtime is running.
I updated the license an hour ago. I got a "Success" dialog box.
Does anyone know what is going on and how I overcome this problem?
Thank you,
Scott
VladimirNAnswer
Article -"Configuration client is not connecting to the Runtime service in PTC Kepware Products": https://www.ptc.com/pt/support/article/cs296144
VladimirN24-Ruby IVAnswer
Thank you!
You're welcome.
