7-Bedrock
Custom/formatted handlebars - IoT Gateway Advanced Template
I know the idea of using REST Client is to push data that makes sense and let the REST Server handle the other side of things.
Howerver, the "otherside" in my case isn't as flexible. And the usecase am in, things will work only if the "|SERVERDATE|" send the actual date in yyyy-mm-dd format
Anywhere around having other handlebars variables to be used outside the |VALUES| part of the advanced template?
MRohillaAnswer
Support
Greetings,
You may refer to the Advanced template section of the IOT gateway plugin for this.
< https://ptc-p-001.sitecorecontenthub.cloud/api/public/content/59f8a382116e44c3a5d66555bc3f27c9?v=0dfaffcd >
Mohit
MRohillaCommunity ManagerAnswer
Support
Greetings,
Mohit
